I don't care for these long service intervals being recommended by manufacturers these days.
IMHO they just shift the cost of maintenance down the road sometimes with real negative consequences.
One of these being engine deposits on some vehicles because of a neglected PCV valve.
I see so many engines that have the PCV in obscure locations,some bolted in,screwed in,hidden under covers etc.
These more often than not get neglected simply because they cant be easily found and the darn manuals don't specify a change interval.
With tune ups sometimes being specified at 100K chance are the poor PCV doesn't get serviced either,
even then if its not stuck right in the valve cover with a hose connected to it there is a good chance it remains in there for the next round.
Many cars today have screw in valves that are difficult to find,look for the valve even on a GM 3800 GENII engine.
I go 30-50K and change them,this seems to keep things in good working order.
One last thought is using OEM valves instead of aftermarket.
There is such a difference in quality these days that using aftermarket valves can be inviting problems,IMO go OEM.
