I had a Toyota in with a rotted rear brake line.
This line went from behind the engine all the way down the drivers side then across the tank to the passengers side.
What a nightmare or so i thought.I bought some NICOPP brake line online (AA sells it) with the correct ends,typical Toyota mischief,3/16 line with 10x1 nuts but use an inverted flair instead of the more common bubble used on metric fittings.
After cutting the old one out and removing the rotten nuts and under body channel i started feeding the new line into the engine compartment.WOW this stuff bends around the finger with no kinking at all.
I ran it through all the original clips and channels with ease,
terminating it and flaring the end was easier than any other line i ever used.
Two hours total instead of probably double that with steel.
This stuff is 90% copper and 10% nickel,its certified for brake line use and is OEM on Aston Martin,RR,Volvo,Porsche etc.
This line will never rot out,perfect for New England use with all the salt.
Next month i am doing my Expedition complete with this line as the originals are getting bad.
After using this line i will never use steel again.
