Mechanical tips- probably, but here is everything on the analysis:
EQUIPMENT MAKE: 1995 F-150
EQUIPMENT MODEL: 5.8L 351 CI V-8
FUEL TYPE: Gasoline (Unleaded)
OIL USE INTERVAL: 636
TOTAL VEHICLE MILES: 80,045
OIL TYPE & GRADE: Motorcraft 5W/30 (Gas)
MAKE-UP OIL ADDED: None
FILTER: Motorcraft FL-820S
ALUMINUM 2
CHROMIUM 1
IRON 19
COPPER 8
LEAD 4
TIN 1
MOLYBDENUM 2
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 0
SILICON 66
SODIUM 6
CALCIUM 2060
MAGNESIUM 23
PHOSPHORUS 751
ZINC 992
BARIUM 12
INSOLUBLES .5
FUEL WATER 0
ANTIFREEZE 0
TBN 5.5
FLASHPOINT 380
SUS @210 60.1
An oil pan gasket was replaced at the end of this interval- about 100 miles of it. I just got this truck and the owner had the oil changed at the dealer while he was having some warranty work done to it. That is why it is such a short interval.
The idle is not "rough" per se, rather it is "slightly shaky" and the exhaust smells rich. I have not pulled the EGR yet to check if it holds vacuum or if it is carboned up, I just noticed that when I sprayed on top of it, the idle changed. If the EGR pintle is fully seated at idle it will not let the exhaust gases by, but if the diaphragm has a hole, maybe the air could get through to the throttle body???
Thanks for your input,
Bill C.
[ April 21, 2003, 07:53 PM: Message edited by: billman ]
