Vehicle is a 2004 Ford Taurus with 3.0 Vulcan (Car has 107,750 miles)
I have an interesting thing happening that is hard to describe. While accelerating under a normal load (idle to ~3,000) the car will increase in RPMs just fine until about ~2,600 RPMs then the needle on the tach will just fall down to 2,200 RPMs and hang there for 2-3 seconds and then continue to climb normally again. Meanwhile, the car never stutters or hesitates. There is a slight feeling of a loss of power, but barely. There is not an audible difference in engine sound or any other noises. It ONLY does it during this RPM range. Above or below this range it runs like a top.
I used my scanner on a few runs to check for codes and watch a few parameters live. The computer is pulling timing during this little event from ~18* to ~6* and then it shoots back up to ~18*. So something IS happening, I just do not know what is causing it.
The plugs have ~10,000 miles on them (Motorcraft OEM). The coil and wires are factory.
Should I spend the $120 and put a new coil and wires on or should I pay the dealer to put the screws to me? Nobody can understand what I am trying to explain here when I ask people about it.
