I have a customer who has a '71 Mustang Mach 1 with a 351 Cleveland. He runs 20W-50 in it.
He came in to my shop a couple of days ago with a sheared distributor gear pin, so we pulled the distributor and replaced the pin.
He indicated that this car has had a propensity to shear distributor gear pins, and that this is not an uncommon problem with 351 Clevelands. When I heard this, I began to query him about running overly thick oil in cold weather - it has gotten into the low 30's lately - my goal was to find out if these pin failures have occurred primarily in cold weather, or if this wasn't a factor.
My thinking is that running 20W-50 in 30F weather makes it much more difficult for the oil pump to pump oil when the engine is cold, thus causing the distributor pins to shear. Ford used hollow formed pins, as opposed to solid pins to secure the distributor gear on the distributor shaft.
What do you think - could the 20W-50 be causing these failures?
Thanks, in advance, for your comments and thoughts.
