Originally Posted By: ronrackley
I have no experience with RP, but I have a lot with synthetics since I became sold on them in the 1980s back when Mobil 1 was the only synthetic brand you could find on store shelves.
After being pretty loyal to Mobil 1 for many years - I did run some of the other off-the-shelf synthetic brands occasionally as they became available just to see how they were - I switched to Rotella T Synthetic ("RTS") 5w40 about five years ago and it has worked very well in every vehicle I've put it in since. I switched out of concern for the additive changes that were being made to oils rated for gasoline passenger car use and also the price increases for Mobil 1 at the time. RTS 5w40 has since been renamed T6 by its maker, Shell.
Being a dual rated diesel/gasoline oil, T6 is allowed to have a more robust additive package than the passenger car only oils can have now. It is also made of a Shell base oil about which you read a lot of great comments by people with expertise in base oils.
My cars are 6 - 13 years old and T6 has additives at levels that the best gasoline passenger car oils had back when my engines were designed, and even more when it comes to the additives that clean because it is mainly a diesel oil. I get outstanding UOAs with it. My engines sound good and run well on it. Oil consumption is, if anything, down a little with it. Trials on long Interstate highway runs indicate that the penalty on gas mileage of the thicker 40 weight is on the order of a small number of tenths of an MPG - maybe a percent or two overall. That's an acceptable tradeoff to me for extra-long engine life. And, last but not least, is that it can be bought for very good prices in gallon jugs off Walmart shelves anywhere I go.
With all that said, I am about to try some Rotella T5 synthetic blend 10w30. Being a dual diesel/gasoline rated oil it has the heavy duty additives I want. And, all other things being equal, I like the idea of it being 30 weight at operating temperature because that's what the manuals say to use. I should get back that percent or two of MPG. On the matter of it being a blend, I'm not too worried about that because they are refining much cleaner conventional base oils than they were when I became sold on synthetics in the 1980s.
Awesome information, Thanks for the input!
