I recently started changing my own oil after a nearly a 20 year break. (Last oil change was in my 1977 Olds Delta 88 (Indy Pace Car colors with a 403 motor)
Now I have a 2006 Honda CRV that I drive about 7500 miles per year, mostly stop and go driving. I also have a 2006 Dodge Caravan that I drive about 4500 miles per year, mostly stop and go driving.
Changing the CRV is easy, I don't even need to lift it. The Caravan on the other hand needs to be raised. Also, changing them at this time of year in the unheated garage can be challenging.
I was thinking about using a Liquivac
My question is if I use one of the Amsoil high efficiency oil filters, can I go one year without changing the filter, if I change the oil every 2-3 months using the Motorcraft Synthetic Blend or am I asking for trouble.
