I scored this old snowblower for free earlier this winter. It leaked fuel out of the carb and wouldn't run at all. I fixed the leak and the no-run problem (ignition was grounding when it shouldn't have been) and got it to run. It ran for a few minutes before it banged/clunked/crunched. It no longer has any compression, so I'm pretty sure the engine failed internally; I'll do a tear down when it warms up!
Since the unit it still solid, especially the auger unit, I decided to install a new engine on the chassis. After some research on BITOG I decided to go with the 6.5 HP Harbor Freight / Greyhound 66015. In addition to getting great reviews on the Harbor Freight (HF) website (if you can trust those), the engine is only $99 if you get your hands on the coupon. An absolute steal! Another bonus is that the physical specs on the HF engine match the existing Tecumseh H60-75216H almost exactly. Shaft centerline height, mounting holes, shaft and keyway size and "shaft face" mounting holes are all identical.
I believe this snowblower to be a Lambert from a picture I found online of a Lambert snowblower. There is no brand-name labels on the unit, just a placard with a model number (53600300 FA9) and an address (P.O. Box 377, Des Moines, IA 50302). That address once lead back to "Western International Inc."
Some surface rust, but the unit is really solid. I plan on cleaning up the rust and repainting this summer. For now I just need to get it running for the remainder of the snow season. We are basically at record snow levels this season in Minneapolis.
Engine removed. Thankfully it was 4 bolts and not studs.
Clutch/Spring loaded pulley tensioner. This bolts to the engine face with two of the four tapped holes.
File photo of the HF engine. Going to purchase this weekend.
More info and picture to come!
