Here is my 54 week run of Mobil 1 Tri-Syn 10w-30.
5 qrts. M1 10w-30 2/28/02 with new but very old stock "Sears" oil filter (PH8A equivalent). Total miles on 1983 5MGE (straight 6 DOHC with aluminum head) engine now at ~184K miles.
Drained and sampled oil 3/13/03. 1/2 qrt. of O'reilly's Dino makeup oil (either 10w-30 or straight 30) and 6 oz. of Neutra 131 added about 6 weeks before draining. Total miles on sample about 7-8k miles (odometer not working). Everyday short trips to take kids to school and back less than 2 miles round trip and 75% of miles in City driving conditions. Car is garaged most nights so morning starts are above freezing year around.
Lab results first column is current from Schaeffer's and the second column is my last analysis from a local lab way back in 1996 - also with M1 10w-30 on a 8K miles annual run:
I'm happy to see the viscosity holding up to a solid 30 weight. I wonder if the 6ppm of Moly means the O'Reilly dino makeup oil now has Moly? I would doubt it as this oil was purchased over a year ago. (O'reilly's is a chain of discount auto parts for those not familiar with the brand name.)
Glad to see the lead down to a more reasonable level as the 1996 reading of 36 was noted to be slightly elevated. This engine is very clean and I couldn't tell that adding the #131 made any difference. Overall looks like everything is OK to me but it would have been nice to see copper a bit lower. Other comments welcome.
Comments from Schaeffer's: Contamination and additive depletion levels normal. Maintain current drain interval.code:
Current 1996
Copper 19 12
Iron 20 18
Chromium 3 3
Aluminum 4 5
Lead 17 36
Silicon 7 10
Moly 6
Phos 736
Zinc 829
Magnes 1325
Calcium 849
Antifrez 0%
Fuel N
H20 .0%
Vis cst 10.64 11.37
Nitration 33
