Does anyone know a carb additive that will stop or prevent water renention & aluminum oxidation?
Long story made short, I had to remove my recently rebuilt Carter AFB carbs to check for problems & found orange-ish/brown gas & white deposits in the bottom of the bowls, which means water in the system. I've cleaned everything out,checked the filters,& changed gas stations.
I can buy non-ethanol fuel some, but not all the time, so I need an additive that to use when having to buy ethanol. Some boards on the net tell you to NOT use alcohol additives w/ethanol gas.
Any suggestions?
Any suggestions?
