Oil weight and capacity for 98' ford E-350 15 pass
ohio
I bought a used 98'E-350 15 passenger van. It has a 5.4 V-8.I was told it took 6 qts. of 5W20. When under the hood I saw a facctory sticker that specified 5W30 oil. Also written near the oil fill cap was"7 qts." Anybody familiar with this situation? Thanks
When I had a 1999 vintage 5.4L, it took about six litres, if I recall correctly. 5w-30 was specified at the time. I know that Ford back speced a lot of engines to 5w-20. I'm not sure how far back that went, but others here will certainly know.
Non flex fuel or CNG.
CAPACITIES:
Engine, with filter..........6.1 quarts [1]
Cooling System, With RR HEAT Initial Fill..........31.2 quarts
AMSOIL Antifreeze and Engine Coolant
Cooling System, Without RR HEAT Initial Fill..........29.1 quarts
Automatic Transmission, E4OD Initial Fill..........6.5 quarts
Automatic Transmission, 4R100 Initial Fill..........6.5 quarts
Automatic Transmission, Total Fill
4 speed 4R100..........15.7 quarts
4 speed E4OD..........15.7 quarts
Differential, Dana 70 EX HD Rear..........6.6 pints [2]
Differential, Dana 70 HD Rear..........7.4 pints [2]
Differential, Dana 80 Rear..........8.3 pints [2]
Differential, Dana M60-IU Rear..........6.4 pints [2]
Differential, Ford 8.8 or 9 R Rear..........5.5 pints [2]
[1] When refilling, remove dipstick to provide adequate venting
and allow oil to flow into crankcase.
[2] Fill to no more than 1/4 to 9/16 inch below fill plug hole.
5w30, 6.5 quarts. Frankly, in this motor, I like Castrol 0w30 (GC). GC, and an FL820S, every 7.5k for normal driving, and call it good. 15 heavyweight folks, and towing the marching band trailer, I would cut it back to 5k OCI.
Original fill was 5w30, backspecified to 5w20. Listed capacity is 6 quarts, generally will take 6 to 6.5 - you'll have to find out.
If it were me, I'd stick with a quality 5w30, a motorcraft FL-820s filter and call it a day.
Thanks for all of the info.It sure helps. I will use 5w20 Napa synthetic in the cold months and 5w30 napa syn in the warm months. Will use 6.1 qts and monitor via the dipstick. I always use Napa Gold filters.Change every 4000M.
