I personally don't think it is needed in a newer vehicle. That being said, after say 2 years or 30K or so, I would start using it once in a while. I like the lube properties of MMO or Lucas as much as anything, especially in vehicles that have fuel pump issues like GMs have certainly had. I also like regane. I also believe that older vehicles that ran a lot of years on the higher sulphur fuel can benefit from a cleaner like MMO if the previous owner (which is most of them) never used a fuel system cleaning product. I have posted before on my experience with regane and a 98 Ford that was owned by a 'frugal' older couple since new. I asked all sorts of questions about the maintenance they did and what gas they bought, and the guy just sort of looked at me weird and said that they just fixed whatever was broken and bought gas wherever was cheapest and took it to quikie lube a couple times a year. I put the higher concentrate regane HM in the 14 gal tank and drove it fairly hard, and saw a difference for sure. Abt 1 MPG better and it started idling great and actually started idling at the RPM that the manaul said it should. It was about 150 RPM low before the Regane treatment. I now use MMO on every other tank on it to keep it cleaned and lubed.
