Originally Posted By: PDX2500HD
All makes sense Onion, However... Allison does recommend TranSynd in ALL their boxes, including the one's sold for GM (actually made off sight at a GM facility).. There is a bit of tension on this I know because I've contacted Allison about it and they say "we have to tell you up front, that GM recommends Dex VI, but we disagree and recommend TranSynd" ... I then dug deeper into GM's engineering and got them to admit that for "severe duty" they recommend TranSynd over Dex VI.. As a matter of fact, when it's really cold it's specifically listed as being recommended in this marketing brochure generation with GM and Allison (read toward the last page)..
I'm sure both are "Fine" but I'd be willing to bet that at least for severe duty or long drain intervals (i.e. going 100,000 miles in a car), the TranSynd is better, it's made for severe duty from the get go.
http://www.allisontransmission.com/servl...et=SA5521EN.pdf
That's an interesting bit of information on the brochure:
Quote:
Allison recommends using TranSynd™
uid in those areas where transmission fl
the minimum ambient temperatures are
below -40 degrees F
I doubt that either of us will be operating in -40 degree weather... but it's still interesting.
As for the GM engineers that you mentioned:
Is this anything in writing, or better yet something that you can provide a link for? Or was this an over-the-phone conversation?
below -40 degrees F
