Originally Posted By: mechanicx
I've never used ramps and always used a floor jack and jack stands. Any serious mechanic or DIYer needs a floor jack and jack stands more than they do ramps. If I needed to raise the car to get to the oil filter or even the drain plug for an oil change, that's usually a good time to do a tire rotation. You can't rotate tires with the tires on ramps. Although, I can see ramps being easier if all you need is the car lifted to change the oil. I just never did it that way
This isn't a discussion about whether one should buy ramps *OR* jack and stands. It's about whether you can change the oil on ramps, and you certainly can do so.
I have both setups, and use ramps whenever I have the option to because they are more stable and safer when used properly IMO.
