I've been doing some remodeling work in my basement which included tearing out a (poorly-constructed) room that had been built by previous owners. The footers of the wall structure were attached to the concrete floor by threaded studs that were anchored into the concrete. (The stud was anchored into the concrete and came up through the footer and was secured with a washer and nut.) The wall studs were attached to the foundation wall in similar fashion.
Now that everything is torn out, I have two dozen studs sticking out that I need/want to cut off flush with the concrete. Carpet will go over them on the floor and the walls will be patched with hydraulic cement and then painted/sealed with Drylok or a similar product.
Here's my question: Does anyone have a tip or recommendation on how to cut off the studs flush with the concrete?
A Dremel with a cutting disc comes to mind but I don't have a Dremel. Though my birthday is coming up and my wife is looking for gift ideas.
