Originally Posted By: OrdnanceMarine
What I don't buy is the claim that the fill is good for a "lifetime". Transmission fluid life is totally dependent on operating temperatures. My guess is that a car like the Elantra isn't going to get much of a chance to overheat the transmission and chew up the fluid's life very quickly so perhaps it's a non-issue?
I think it's a non-issue. The '97 Cadillac that my mother owned, then I owned, then my brother owned, then eventually got traded off at 180k miles, had the original Dexron III for its entire life. Owner's manual said it never required changing unless driven under certain high-heat conditions (towing, taxi driving, etc). And it was right: that transmission shifted very smooth and flaw-free for its entire life. I already think that GM Hydramatics are, as a whole, one of the better transmission lines in the business, but that 4T80-E was just plain flawless, even with its "lifetime" fluid.
We ran the original ATF+4 for 76k miles in our '03 Grand Caravan without a problem. I'd have kept it in there for 100k miles anyway, and probably much more. It was supposed to be a "lifetime" fluid, and it was holding up just fine. We traded the van, so I never got to run it longer.
My Camry has "lifetime" fluid, as well as a sealed transmission, and I have no intention of changing it prematurely. These modern ATFs are fully synthetic products, and transmission fluids don't suffer near the environmental hazards that engine oils do (like fuel dilution, blowby, etc). I agree with the previous posts that sealed transmissions stay cleaner longer, and the risk of the improper fluid used is reduced to near nothing.
I will be changing the ATF in the MDX soon, but only because Acura recommends such. If it didn't recommend it until 100k miles, or if it didn't recommend it at all, that's what I'd do.
