Details: Oil - Amsoil 10W-30 ATM. Car is a 1999 Volvo S70 with a high pressure turbocharged 2.3 L (236 HP) engine. It is running a Mann/Volvo oil filter and a K&N drop in air filter. Miles/time on the oil is 5600 miles (about 5 months). Miles on car is 51003 miles. First column is previous analysis (conducted by OAI in-house) and had 5530 miles on oil; same brand/type oil, same air filter, same brand oil filter, about same time in crankcase. Second column is the current analysis, purchased from OAI, but contracted to CTC.
Prev. Current
Fe 7 16
Cr 0 1
Pb 1 0
Cu 8 12
Sn 2 0
Al 6 4
Ni 1 0
Ag 0 0
Mn 1 Not Reported
Si 3 4
B 34 3
Na 3 8
Mg 356 345
Ca 3348 2724
Ba 0 0
P 1248 1286
Zn 1526 1393
Mo 5 1
Ti 0 0
V 0 0
Cd 0
K NR 0
Gly. Neg Neg
H20 Neg Neg
Fuel 1.3% Vis @ 100 11.7 12.26
Oxd 15.6 16
Nox 37.1 29
TBN 8.3 5.61
Note the difference in TBN and Vis @ 100. Generally, the current analysis is not as favorable. I understand the TBN issue between the two labs, but I don’t like the way the oil thickened in the current analysis; barely a 30 wt. Next sample will be with Shaeffer’s 703, same interval.
Prev. Current
Fe 7 16
Cr 0 1
Pb 1 0
Cu 8 12
Sn 2 0
Al 6 4
Ni 1 0
Ag 0 0
Mn 1 Not Reported
Si 3 4
B 34 3
Na 3 8
Mg 356 345
Ca 3348 2724
Ba 0 0
P 1248 1286
Zn 1526 1393
Mo 5 1
Ti 0 0
V 0 0
Cd 0
K NR 0
Gly. Neg Neg
H20 Neg Neg
Oxd 15.6 16
Nox 37.1 29
TBN 8.3 5.61
