"My feeling is the benefit of using anti seize on lug nut studs outweigh any concerns of problems it may cause. I do think it is a good idea to apply the anti seize very sparingly to the lug studs, and to try to not get any anti seize on the contact point between the end of the lug & where it seats in the rim lug recesses."
lol, I torque almost everything by feel anyway. Just did a torque arm insert. It was 65ft-lbs +1/4 turn (?) I did it till it felt right. I'm actually going to check it over time and if it loosens I'll add a helical spring (split) washer.
http://www.boltscience.com/
