Post your latest oil change
2010 Ford Fusion;
-5qts Pennzoil Ultra 5w20
-.5qts Motorcraft 5w30
-Motorcraft FL-910S filter
19,950 miles.
Also used some Regane before the OCI.
Wife's '97 Camry 4 banger.
145k miles.
4k miles on Maxlife 5-30 & PureOne.
Oil stays tea colored & the engine runs great.
Put in Maxlife 5-30 & another PureOne.
2005 Pontiac Pursuit 2.2L L4 Ecotec with 48,079 miles
5 Qts (4.7L) Formula Shell 5W-30 (API SM)
Napa Gold 7082 (by Wix) filter
1996 GMC Yukon
Valvoline Maxlife 5W-30 syn blend and AC Delco PF52 filter.
Previous fill: Rotella T5 10W-30 (started to leak a lot more and only had 2.7K before changing out--leak looks to be slowing with the Maxlife)
2001 tahoe
6 quarts of 5w-40 rotella t6
napa gold filter
2006 dt466e 7.5 gallons of 5w-40 rotella t6
wix extended duty filter
2001 Nissan Maxima SE (365k miles)
4.25 quarts Valvoline Max Life 5w30
Bosch DistancePlus filter (bought as part of AAP's Syntec oil change special this month. The Syntec goes in my GTi)
just did a 2000 f150 5.4 with 200k
6 quarts GTX HIGH MILEAGE 10/30
Fram Tough Guard (autozone special)
the filter that came off was very small, like a honda filter.
if you use an oil change shop better watch closely, because it could happen to anyone
Regal GS 210,438 miles;
out: PU 5w30, 24011 P1, 4400 miles/6 months exactly
in: 4 qts T6, ~.5 to .7 qts T5, same filter.
2004 Ram 1500 @ 111,682 miles. Drained M1 AFE 5w30 8,830 miles (4 months).
Filled with Edge 5w30 and oversized K and N filter.
