This is my wife's 2007 Acura RDX, which is primarly used for her short daily commute, as well as general weekend errand driving. The car sees much more city driving than highway, which I believe is the cause of the OLM running down so quickly - 5% life showing at 2756 miles, which was around 9 months. Total mileage on the car is 14,318.
As we get closer to the end of the warranty period, I wanted to get a sense of how conservative the OLM is for our type of driving. This is the first UOA, but looking back at past records, the change interval has been fairly consistent.
Code:
Acura RDX
Mobil 1 5W-30
2,756 Miles
5% OLM
Comments:
You mentioned this engine sees a lot of short trips and that the OLM was down to 5%, and we
think that is a little conservative based on these readings. Universal averages show typical
wear levels for this type of engine after about 5,000 miles use on the oil. Wear metals were
actually a little above average, but at these levels, we don't think going longer would be a
problem. Insolubles were low, so the oil filter was doing well and the TBN was still strong
at 3.2, so lots of active additive was left (1.0 is too low). Try going 4,000 miles or 12
months next oil.
MI/HR on Oil 14,318
MI/HR on Unit 2,756
Sample Date 01/15/11
Make Up Oil --
ALUMINUM 4
CHROMIUM 0
IRON 11
COPPER 2
LEAD 0
TIN 4
MOLYBDENUM 105
NICKEL 1
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 57
SILICON 8
SODIUM 36
CALCIUM 2343
MAGNESIUM 12
PHOSPHORUS 695
ZINC 719
BARIUM 0
Values
Should Be
SUS @ 210°F 56.4 55-62
cSt @ 100°C 9.18 8.8-11.1
Flashpoint °F 375 >365
Fuel %
Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.2
TBN 3.2
Code:
Acura RDX
Mobil 1 5W-30
2,756 Miles
5% OLM
Comments:
months next oil.
MI/HR on Oil 14,318
MI/HR on Unit 2,756
Make Up Oil --
ALUMINUM 4
CHROMIUM 0
IRON 11
COPPER 2
LEAD 0
TIN 4
MOLYBDENUM 105
NICKEL 1
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 57
SILICON 8
SODIUM 36
CALCIUM 2343
MAGNESIUM 12
PHOSPHORUS 695
ZINC 719
BARIUM 0
Values
Should Be
Fuel %
Water % 0.0 0.0
Insolubles % 0.2
TBN 3.2
