Sayjac
Thread starter
Originally Posted By: vlado11
Early QR2.5's had issues with pre cat internals falling apart and particles being ingested back into the engine causing piston ring damage and oil consumption. Unfortinately, that looks like what happened in your case.
Some '05 and '06 2.5 models have oil consumprion issues because Nissan got a bad set or piston rings (out of spec?) form a supplier. Nissan gave [censored] to owners of cars that have been sold and their suggestion was to just keep ading oil in most caseses, and even excessive consumption (can't remember the exact amount/mi) was according to Nissan normal. New cars were pulled off the lots, and engines were rebuilt with proper piston rings. My '06 is one of them, and the engine warranty was extended to 10yr/100k mi. My Altima is at 90+k mi now with zero breakdowns, but engine has been making loud rattling noise when warm since new (comopared to other same year 2.5s) which according to Nissan is normal.
My '08Z with only 16k mi has serious tire cupping issue up front. Nissan says alignment warranty exprired after 12mo/12k mi and I'm on my own. Early- '03, '04Zs had this problem, but I figured it was fixed by '08 and I did not look into this before I bought my new Z. Nissan's fix for the early Z's was to swap the front tires side to side, and to re align the car to their new specs. Most owners have never resolved this issue, and most years seem to be affected. I purchesed my Z with auto trans, because their 6-speed was revised 9 times between '03 and '07 due to syncro failure issues. I'm not looking forward to having to fork out $500 every 16k mi on new front tires/alignment, so I'm DONE with Nissan also. Might go with aftermarket suspension in the future to se if it helps the cupping/feathering.
Coming from a multiple car Nissan buyer, I think your post speaks volumes. You did a good job of chronicling the history of the ill fated 2.5L engine. I'd only add the persistent crank angle and camshaft position sensor issues, but again that is minor compared to engine failure issues.
Also noticed there was nothing negative about your 97 Altima with 182k. That would be before the 99 Ghosn/Renault alliance, which IMO does seem to be the demarcation point for a downturn in Nissan quality.
