quote:
Originally posted by Spector:
quote:
Originally posted by Pablo:
Uh, Spector, Bob works for Schaefer's. Not that there is anything wrong with that, but....
True, but he is not testing or reporting on the oil in this test, just the the filter, or lack of one. I don't care if he uses Schaeffer's oil as long as it is the same oil. It is also a matter of WHO do you trust!
First, I think that people should be trusted until proved otherwise. I am the first to offer respect as I want to be treated no less, and after these years I've been talking with many of you, I suspect I've not given reason for anyone to believe otherwise.
I make no effort to "push" what I sell on here. I do on occasion offer suggestions but with reasons behind it.(mainly grease) but when it comes to motor oils, Only when someone specifically asks about schaeffers do I then discuss it.
Granted, the first part of this test was to compare synth base against mineral base. Why did I chose to stay with schaeffers? No other brand of oil uses a blend with pao and additives, and the same base mineral/additive without the pao, so to compare just how much does a pao synth base added to an oil will affect the wear numbers.
I think in al's situation, he bought the first full 5w30 schaeffers oil and did a trial run, his numbers were no better than the 5w30 blend we sell. He admitted that as I had explain before and pointed out after. He just like the full synth feeling he gets from using full synth's. But in reality, the basic wear numbers were for the most part identical.
So, back to my test, blend 15w30 vers mineral 15w40. Problem was, I added a second element to this test and that was a different filter, so in reality, when the mineral out performed the blend in lower wear numbers, we can't imagine a blend with pao synth being our performed by taking out the pao right? So, now we focused on flow(through the filter). Now, to continue with this, I kept the fram filter in, ran the mineral 5w30. Two things here, I lowered the viscosity, still using the mineral and still with the fram filter. Again, the numbers lowered even more. I now have a test report sent in waiting for response back where I had switched back to the 5w30 blend again with the fram filter. This is where I'm looking to see how much if any the pao helps in wear reduction. IMO, I don't expect to see much. Keep in mind, I'm not in cold temps and not running extreme heat / oil drains.
The conclusion I'm looking for is this...
by using a standard additive and mineral base oil on the blends and mineral oils, my point of synth base oils ALONE do not provide better WEAR protection but DO provide better cold weather flow and extended drains.
Now I'm past that stage and I'm now working on the flow issue and by having data with a 14.00 high end m1 filter, vers a fram filter, vers no filter, we should see how a full flow filter may or may not provide much use. By all rights according to filter companies, the filter should provide better protection than not running a full flow. My opinion?, I think again that full 100% flow to the bearings as a primary concern will out weigh filtration in this case. Next step once completed this next 4k miles without a filter, now install a bypass filter again leaving the full flow filter out and still provide 100% flow to the bears.
So, Spector, I think we are seeing some interesting data from the same consistent lab on the same consistent engine with the same consistent driver and with the same consistent brand of oil, and is giving us a better understanding on flow, synth's and filtration.
