Yes, it's very good stuff.
Yes, you can run it in your Dmax.
Yes, it's very expensive.
If you want to know about the specific elemental concentrations for oils, you'll have to research each one individually (seems that you're on that quest anyway). You can also research the limits of the elements via the API site.
OK - now for a little jest from me to you; meant in good humor.
Ponch - seems like you're on a never-ending quest for the "perfect" oil. What's wrong with the eaisly attained, high quality, reasonably priced CJ-4 lubes all around you? I would think by now you'd know that CJ-4s are excellent. Seems to me you're putting more emphasis on the VOAs and PDS, than the UOAs and such. Nothing wrong with knowing the inputs, but the outputs are what matter most.
Yes, a CH-4 and CI-4 will do well in the Dmax, but so will the CI-4+ and CJ-4. There are benefits to the CJ-4 over the other previous iterations, such as much better soot control. With the reduction of sulphur in the fuel, the TBN is not nearly as important as it once was. In the end, your 2006 LBZ really will run quite well with any of those.
Certainly nothing wrong with asking questions, but it seems you keep looking for the "one" magic, perfect formulation; haven't you figured out by now that the "right" fluid is not limited to only one brand/grade?
Yes - it's cold where you live, but it's cold here too (down to zero deg F OAT this weekend at my house). Try a 10w-30 HDEO. I cannot fathom you cannot find either a dino or semi-syn in 10w-30 (such as T5), given the propensity of farm supply stores and Wal-Marts in MI. Your average low in Bay City is 14 deg F; mine is 18 deg F in Indy. I suspect you occasionally see, but not frequently, below zero temps just like I do. Are you aware that the GM "preferred" vis is 15w-40 all the way down to zero deg F? I prefer a lighter grade, but GM/Isuzu seem confident in their statement; it hasn't changed since the Dmax was introduced. GM does allow 10w-30 or 5w-40 (IIRC) as alternatives; that's why I use 10w-30 year round.
The Deere oil you inquire about is probably 3x or 4x more expensive than a commonly available, brand name HDEO. Do you think you'll get 3x or 4x "better" wear results, or "better" cold cranking, by using the Deere oil over a common 10w-30 HDEO?
I'm not trying to come down on you. I just don't understand why you seem to be so OCD about the oil in your Dmax.
(... yes, I do realize that is the BITOG way ... and most of us wouldn't be members here if we weren't interested).
Presuming you choose an appropriate API and grade level, the Dmax simply isn't that sensitive to the oil selection. Pick one that you like, and rest easy, dear sir.
I'm concerned you're going to suffer a self-induced mental medical emergency!
