Originally Posted By: otis24
I spoke with a gentleman (a farmer of course)regarding the use of ethanol. Subsequently, I have read that E30 and E20 blends can produce MPG equivalent to or better than unleaded gasoline. Any thoughts on this? Secondly, can E20 and E30 blends be used in a non-flex fuel vehicle?
As a previous poster has said, its less energy dense. There is less btu's per volume of fuel than gasoline. Therefore the fuel mileage will be less than straight gasoline. You might have success running e 20 0r e 30 but the components may break down i.e. fuel injectors, o-rings , throttle body components etc. Some vehicles run poorly some run okay.
