my GM 93 1500 blew a high pressure hose today. The fluid that came out smelled like old ATF and was a brownish color. I know people have used ATF in these pumps and in some case it was called for. My book calls for PS fluid. Well i had qt of Valvoline regular PS fluid in the shed. I changed the hose and then cracked the high pressure side and flushed enough out to use the entire qt of fluid. It still looked brownish so i decided to run to the parts store to get another qt and it is 6 dollars a qt for valvoline, 4.50 for prestone and Valvoline Maxlife and about 4 for house brands. I decided it was clean enough for now because im curious about mixing brands as there appears to be no API like spec to look for. Also does anyone know what the typical system volume is? Im thinking running a qt thru it would get most of it. Any info is appreciated. Im wondering if i should have just bought a gallon of ATF and ran it through it. 5 dollars a qt for PS fluid seems a little steep. Im planning on flushing all three of my trucks. ALL GM so i may use ATF on my other two.
