Originally Posted By: scott37300
Originally Posted By: GMBoy
SAVE YOUR MONEY!!
This is all you need:
http://www.midwayautosupply.com/showproduct.aspx?productid=84975&affiliateid=10050
I do my "on the fuel rail" cleanings using only this. I used to buy the 3M cleaner, but at near $20 ... I now use BWD Procleen that can be found at O'Riellys (behind the counter) for $9.95 and it works just the same.
Just remove the fuel pump relay, pop the hose on the can, thread on the fuel rail and turn it on and start the car.
That hose you linked to is just an update part for the lisle 55700 fuel system kit. It's not designed to use alone. You may be able to but how do you regulate the pressure you are sending the cleaner in at with out using the regulator in the full lisle kit?
3M, Lisle, OTC all make complete kits that are pretty nice. The OTC and lisle use cheaper chemicals, I know the OTC uses a chemical you pour into their setup. I don't own a business and will only be using this 1-2 times a year at most and already have the 3M kit. So I am going to stick with what I have, an extra 10 bucks per vehicle isn't a big deal when you are just doing your own vehicles. Even if I got just the hose you linked to it's 50 bucks, so at a 10 dollar savings per car it would take 5 cars to make up that savings. If I was a business it would make sense but since I already have the 3M kit and only using it once in a while it makes more sense to stick with that.
You don't need to regulate the flow - the can is pressurized and the engine runs off of it. Trust me - I bought my first "cleaning kit" from Ecklers Corvette sales. It included a very similiar hose and a can of 3M cleaner...all for under $50. I've been using it for over 10 years with fine results. Now - I do also own a cannister (professional cleaning kit) unit that cost me about $300 used from a dealership that went out of business, but I only use that for chemical in regular bottles not under pressure. I will put B12 or something in there and run it thru the fuel rail.
I'm just saying that the kit is waayyy too much money for what you get. Heck -you can get a fuel pressure gauge, the hose and the cleaner all for about $80.
