I cannot believe it. I host a little Honda CRX forum and I thought it was my duty to inform my members about the orange-can-of-death. Well, less than a few days later, my website gets a lengthy post from a Fram "technical manager" stating that my information is false and Fram is the best, blah, blah, blah... Here is the post:
"Hello,
I am the technical manager at Fram. I am wondering why you think Honda would risk their stellar reliability reputation by using an inferior filter? What you are posting is simply not true. The filter end caps are not paper or cardboard, they are made from an engineered fiber, just like the filter media itself. In fact, many companies are now using fiber, felt or no end caps at all. The Champ labs filters are all being made today with what is called the "E core" design, it uses a felt end cap and plastic center tube. They make filters for AC Delco, Wal-Mart and others. Bentley Motor cars uses fiber end caps in the oil filter on a 345,000$ Bentley Arnage. All Toyota OE filters now use no end cap at all, just glue to seal the ends of the filter media. What is important in oil filtration is how much dirt the filter removes from the oil on the first pass. The least expensive Fram filter is 94% efficient using ISO test standard 4548-12. This means it removes 94% of dirt particles in the 10-20 micron size the first time your oil passes through the filter. The Super Tech filter is around 80% efficient in comparison. Your question about why the Fram Extended Guard filter uses steel end caps? The XG filter is the most advanced, highest capacity filter in the market. It is the ONLY filter that has a wriiten guarantee for 10k oil chages when used with synthetic oil. It has two layers of full synthetic glass media wrapped around a stainless steel mesh screen. The end caps are used to contain the steel screen. If you really want to know about what is important in filtration, I would be happy to give you a tour of our engineering labs in ohio to show you how filters are tested. The fiber end caps have been in production for over 15 years with a zero failure rate. Honda uses them, Subuaru uses them, General Motors and Bentley use them."
Wow, I didn't realize Fram was paying it's employees to troll websites and forum to seek out and destroy all negative posts about their products.
"Hello,
