quote:
Originally posted by Tempest:
Is it common for large trucks/buses/machines to use oil instead of grease in the wheel bearings? If so, is there a sump/pump/filter arrangement? Or is it a simple oil bath?
Yes.
It's just a simple oil bath. As the bearing rotates it just dips into the oil.
1040wreckerman. I wired the shutters open.Truck has a T-stat in it so they are not really needed. I didn't trust the thing to open them plus I think it looks better with em open.
The wheel seals were worn down to the garter springs. I replaced them with a different style of seal. I figure I'll run it till I need to replace the brakes on that axle then I'll swap it over to oil.
May possibly make it into a 2-axle so I may end up ditching the tag. Truck was originally a 2-axle with a 187 wheelbase. I bet that rode nice.............Not!!!!
I plan on doing the other side this weekend then tackle the drive axle since it's really throwin oil.
The AC unit is an "Ideal-Air". Same thing as a RedDot. It's in pretty bad shape. Has rust and both blowers are locked up. I don't think it's ever been used though. While messing around up there I determined that there's no oil in the drier or lines.
The end of the lines are flare fittings and don't appear to have ever been attached to a compressor.
There's no mount on the engine or extra pullys for a compressor.
I think someone was going to add AC and never finished.
I wish it wasn't there. If I remove it I'll have a big huge hole in the roof and headliner. My cost on a new one is $1200. I can get an under dash setup that has AC and a heater for about $400.
