Originally Posted By: musicmanbass
I get that, but I hope to heaven that our esteemed BITOG readers arent silly enough to dose based on tank size, and not for the amount of gas actually added to the car!!!!
Quick reality check: we all do understand that when we go the station to get gas, the tank is not COMPLETELY empty unless we coasted in after running out of gas, right? Therefore we are not pumping in a full tank of gas. To continually dose as if we were would be kind of foolish.
So say my car holds 20 gallons of gas. I don't just dump 20 gallon's worth of additive if I add 15 gallons of gas!!!!! What am I missing? Am I the only here that thinks this way?
We have one gentleman sharing his ratios down to very finite detail. I seriously doubt he throws all that work out the window and pours 8 oz MMO in the tank no matter if he's pumping 5 gallons or 20.
I hope I'm explaining what I mean properly. Please let me know if I'm being unclear, or if I'm not understanding this properly. It's been a very long day and I don't doubt that I could be completely missing the point!
Oh, and of course this discussion pertains to continual maintenance doses of a product. Dumping a bottle of Gumout twice a year is a different animal entirely.
Simply put base the dose on the amount of gas you are adding to the tank. I'd hope the members understand that. I can tell by the position of the gas needle how much gas I'm going to take, I add my MMO or TCW3 at the station before pumping so I get a good mix. If you can't estimate how much gas you are going to take add the UCL after you fill up.
If you are real anal, add some UCL [less than you'll need] before you pump, then adjust the dose once you know how many gallons you took.
