94 Ford Explorer in my sig...Replaced the water pump last week. When I installed it, I used the supplied gasket. As soon as I started refilling antifreeze, it started leaking profusely. I took it apart and took the gasket off and used blue RTV instead. Both times I cleaned the gasket surface well. It held up well for a few days, but now it's starting to leak again. I'm about to head to Napa and pick up a tube of "The Right Stuff." I heard nothing but good things about it. If anyone has any other recommendations or suggestions I'm all ears. If it leaks after this, I'm taking it to a shop because I have HAD it with this thing.
