Lubrication for interior components...
AZ
Anyone ever need to lube the tracks for their motorized seat belts?
My '91 Mazda Protege' has the passive restraint system and being in the desert for 7+ years may have aged the lube in the tracks & attracted lotsa grit. OK operation when its warm but cold weather makes the belts move like pond water! Any tips on a good lube/grease?
P.S. Power sunroof is moving slow as well..
Johnson Controls uses a NLGI Grade 1 lithium soap thickened mineral oil grease for the seat assemblies they supply to manufacturers. I imagine any light-bodied lithium based grease should do the trick. Ideally, you should clean out the old grease.
The sunroof is a completely different matter. Somebody makes a special lube for that application.
