I have been running the Odyssey van with nothing but Mobil or Shell for last couple of years and it had been running well. Over the break, we took a family trip to Northern Virginia. It was running very strong on the way there. I put gas on NJ TPke (Sunoco).
Before returning from NoVa, I filled her up there with Sunoco. The returned trip did not have much zip in the van. The vehicle weight was same. In CT, I stopped at Mobil (most expensive gas) and filled her up along with Techron+ 20 Oz concentrate. Even after 150 miles on that brew, it is still not zippy as it was going down to NoVa. I always time to fill the tank in NJ but this time, the line was huge. We should not have waited until the last rest area. I generally try to fill at next to last.
Since we make this trip quite often, I always find myself with similar issue i.e. performance drop-off somewhere during the trip. It is real and I wish I could figure out what causes it. My logical mind does want to believe it could be just brand of the gas. I do not have real time scanner on this vehicle to see if ECM is retarding the timing etc.
Do you run in to similar issue on long trips?
- Vikas
- Vikas
