Need some bobistheoilguy advice on this one. Parts changed on power steering system and air was introduced into the p/s system. Confident the noise my system is making is not the p/s pump going bad but air in the system.
Tried bleeding it by turning steering wheel back and forth. Saw some air plus p/s fluid bubble up out of the power steering reservoir. Thought this would fix it but the sound persists. No indication at this point that the pump is bad.
I researched further and apparently this particular car is one of several that tend to REALLY trap air once in the system. I was told I need a pump which can be attached to the reservior, somehow you get it completely sealed and pump away. This draws all the air out along with a small amount of fluid which I would obviously replace.
I found several pumps on Amazon.com that state they do this type of job but I see no way on how it can be sealed air tight to allow me to properly remove the air. Any suggestions on the correct pump to buy and how to get it sealed before I start pumping. Thanks for any advice because I am worried that if I leave the air in the system too long it may actually kill the p/s pump over time.
