Originally Posted By: Ben99GT
Originally Posted By: Trav
I honestly don't believe anti-seize had anything to do with it.
My 99 expedition 5.4 2V had the original plugs changed at 30K,they came out very easy and the new ones were torqued to 10ft lbs with never-seize.They have been changed at 30K intervals ever since without any problems whatsoever.
I've always used anti-seize and torque to 10.5 ft-lbs. I also think you are right on the money that the threads get damaged upon the initial removal, usually because they were left in too long.
IMO, the best bet is to pull the original plugs around 50,000 miles from a completely cold engine, use anti-seize (preferably nickel based) to prevent any thread galling next time they come out, and torque to 10-11 ft-lbs when using anti-seize. This has always worked for me.
Yeah, these had what, 200,000Km on them when I changed them? I know they were the original ones. Even after letting them soak in penetrating lube, I imagine you are right, that the threads were probably slightly damaged during the removal process.
