This is correct. Additionnally the solid lubricants.quote:
238 is too sticky for those smaller, higher speed bearings. It'd be OK for big truck bearings. It can't flow into smaller bearings as the correct grease must.
HELLO!!! That's your username,ain't it?quote:
Originally posted by Greaser:
I grease my ball joints twice a year...spring with 238 and in the fall with 231....now I'm mixing greases
I think 238 is especially well suited for slow moving, heavily loaded pins & bushings in heavy machinery. It meets Cat's 5% moly requirement.quote:
Originally posted by MolaKule:
I was told the #238 was more for roller bearings in steel mills and for mining equipment, since it has a lot of graphite and Teflon.
