There was dust in the air cleaner housing and intake tube of my 2001 Silverado last time I had it apart. I'm considering using grease to seal the filter and hose connections, but am not sure what kind to use. The choices on hand are white lithium grease and dielectric silicone grease.
I'm hesitant to use the silicone grease because of the non-"sensor-safe" silicone gasket sealants that can cause problems with computer controlled engines. (Are those problems caused by chemicals other than the actual silicone?) If I used the white grease, on the other hand, would it degrade the rubber hoses and air cleaner seal?
Thanks, anyone, for your help.
