I Ironduke4 Joined May 7, 2004 Messages 182 Location Elmhurst Illinois Nov 30, 2004 #1 I was wondering what grease would be the best to use to lube the gears in power tools like drills,angle grinders,saws etc? Any type of grease that really excells in this application? I was thinking something with moly would be good.
K kenw Joined Oct 10, 2004 Messages 1,979 Location Houston Dec 1, 2004 #2 I've got a tub of Amalie axle grease that I've also used in those type of applications and it has been fine over the eons. Like 20 years..... but then, I'm sure someone has done an oil anal-ysis on power grinder gear grease and has a special blend that works wonders......
K kenw Joined Oct 10, 2004 Messages 1,979 Location Houston Dec 1, 2004 #3 actually, it's wheel bearing grease.
