Dealer pulled codes, said I need to replace the hub. Cost will be just under $800. I am not hearing any bearing roar, can the electronic pickup fail without actually failing the bearing or will it soon begin to fail too?
Also for the fronts on this car I replaced them using Timken replacements at 60,000 miles, now at 97,000 I am considering both SKF and Timken. How do these two compare? I like SKF in their larger bearings, we have used some on 1350 hp electric motors and they had much better performance than the F A G brand bearing the supplier tried first. But how do the hubs compare?
Car is Chevrolet Impala 2003 with ABS.
Thanks
Thanks
