I normally grease suspensions three or four time a year, making sure to add just enough grease to see the seal or boot start to expand.
Have not found any Zerke fittings (yet) on my 2004 TrailBlazer, what is the long term consequence?
Should I use a grease needle to add grease (puncturing the seal or boot in the same spot) say every 25,000 miles, then seal the puncture with a silicon sealant?
Is this an acceptable means to add grease, assuming it will extend the life of the joint?
The manual says to use.....
Lubricant meeting requirements of
NLGI #2, Category LB or GC-LB
on the following....
Chassis
Rear driveline center spline
Universal joints
Constant velocity universal joint
My other question is regarding the “Change Engine Oil” life system. Should I change the oil like I have done in the past (every 3500 to 4000 miles) or let the system tell me when to. The oil capacity of the engine is 7 Quarts.
Chassis
Universal joints
