Now that I have switched to a synthetic grease for use in my cartridge gun, the constant spring pressure is bleeding the oil out of the mix. Not only is this messy but the active ingredent is being reduced with each passing day. Question?? is there a way to release the spring pressure on the cartridge between uses? The gun is a cheapie and resists all efforts to pull back the handle.Or if someone can recommend a make/model grease gun can be made to stop the bleeding. Thanks in advance.
WDP
WDP
