Part of my job is delivering fuel to surface mines (strip mines) where they have above ground tanks for diesel.
We have begun, at the request of 3 of the mines we haul to, to put in 2.5 gallons of anti-gel additive for the winter season.
One particular mine foreman told me that last year, they stopped using the winter additive because he said it was clogging up their fuel filters. When they ceased using the additive, he said his problems with clogged fuel filters ceased---and they never had a problem with the ULSD gelling, even down to zero degrees F.
I looked around the 'net for some info on the cloud and gel points of ULSD, and have found nothing definitive. When ULSD (ultra low sulfur diesel) first came out, it was reported that it would gel sooner than the old regular LSD. I read somewhere that it could gel as early as 20 degrees F. We've since proven that wrong, many times over... but where is the truth?
My intention is to begin running some small samples of ULSD into bottles, and leaving the bottles out in the sub freezing temperatures of this winter (Virginia and West Virginia)... but I'd like to get some info from some folks farther north, where it'll get even colder.
Last week I tested some straight USLD diesel, from the fuel dispenser at the Flying J truck stop in Wytheville, VA... overnight low was 8 degrees F. The fuel did not gel, or even cloud. I had about a quart of it in a clean jug.
Any info anyone can add would be appreciated. These mines are spending quite a bit of money on these winter anti-gel additives, and I'm beginning to wonder how necessary it really is.
I guess the cloud/gel point of these fuels can vary from batch to batch... but there must be a norm there somewhere.
Dan
Dan
