My Kawasaki Nomad motorcycle came from the factory with molybdeum disulfide grease on the drive shaft splines. Shortly I will be re-greasing the splines. I do not want to remove the swingarm to get to the driveshaft to remove the old grease. I just want to add grease to the old. I would like to use a longlasting synthetic grease.
What synthetic grease is compatable with the molybdeum disulfide grease that is on the splines now? I would like something I could buy locally.
Thanks,
Ned
Thanks,
Ned
