Like on a boat sterndrive - which is a splined shaft iside a coupler (no water is involved)
could you use EP trailer wheel bearing grease on it rather than the Merc "spline" grease?
Not talking about gimbal grease (tho I have some of that)
Seems gimbal grease and HP trailer wheel bearing grease would cover the grease spectrum and since they are used on fast rotating bearings be better than spline grease????. Spline move only when triming in and out?
