Hey everyone.
I have a 2001 Dodge Caravan 2.4 L 4 Cylinder.
The other day I parked my van and I slammed the shifter into park kind of hard (didnt mean to). I then proceeded to turn the ignition off and when I did that I couldnt get the key out.
The key is stuck between off/lock position and ignition on.
Everything turns off and motor shuts down but the digital mileage stays lit up all 24/7.
I tried turning the wheels side to side, I tried jiggling the key back and forth, I tried starting and restarting the car. I shifted out of park and back into it.
I can start the car with a half turn and it goes into drive, reverse, 1, 2 , N.
Also this morning when I turned the car on the wipers and radio did not work but the car started and I drove to work, when I got to work I turned the car off and the wipers and radio started to work again. The ignition is still stuck between lock and start but I managed to get the key out but now since the steering is not locked I can shift it out of park with no key.
Can Anyone help me. Any tips, ideas?
I dont want to replace the ignition as the van is not worth dumping money into Id just like to fix this problem because I dont want to park it and someone comes along and steals it.
Thanks guys.
Thanks guys.
