I'm ignorant in this are of DI so please excuse me if I make it to well known... I just wanted to touch on a few things about valve deposits I have questions about.. The valves will still be affected by the combustion process, but does not get the gasoline solvent wash... that thought crossed my mind in a kind of domino effect, once the process starts it seems with a build up on the valves it would start to build faster, and faster because the contaminates have something to hold to.
I'm sure there is some amount of gasoline getting onto the valves, apparently not enough to do any good though. I really can't see how any oil will reduce the valve deposits, unless your getting a lot of blow by.. which in this case I have seen many engines that had blowby, and they were spotless in the combustion chamber area.. it would blow your mind the internals around the head, valve etc would be spotless.. compared to an engine that used no oil, what everyone would call a great engine would be carbonized up as normal in the combustion area.
I'm not sure where DI is going, but this is going to be a hold back for DI until they get it worked out whatever that way may be. I will say that I'm all for DI, but I wouldn't purchase one now because of this... but DI is a far better engineering means of delivering fuel than what we have been using. Less parts, more control of the combustion process, and the option to extend the power stroke out much further driving the economy up.
I wonder if the can raise combustion temperatures high enough to prevent the deposits from forming by requiring a higher compression. As far as I know it's impossible ( I know anything is possible) to use a "non stick" material for the valves, this residue could stick to a greased monkey combined with the combustion pressure, heat etc it seems you couldn't ask for better conditions.
Other things to look at, combustion shape, placement of injectors, and maybe to some extent valve material... and I'm just a ignorant person, I'm sure the car manufacture engineers have much better ideas, and know what they are talking about..
