SBC;
You likely will not have any problems with your moly grease in the U-joints, but is it needed?
When I see "moly-everything" lubricant companies welllllll, does this mean every other oil company has their heads up their ____?
If only life were that simple, ZDDP and moly. What are we going to do when heavy metals are banned from consumer products for enviromental reasons?
What are we going to talk about then? Calcium, borate, barium, and graphite?
Cam talk....
Could an expert on the subject write 10 pages on one event such as the intake valve opening point.
Let me throw this little question out to you...
You have this 325 CID small block Chev (4.128X 3.0) lol'
10.5 compression ratio, brand X heads that have a 215 CC intake port all done up with a 2.125" intake valve. 5.85" con rods.
You want to use this engine in a street driven car, but **** , those heads are big and the throttle response is slow.
To make that little engine snappier at low rpm, you need to speed up the intake port velocity. But how can you do that?
A. decrease the compression ratio
B. Increase the con-rod length to 6.125"
C. Reduce the intake valve size to 2.02"
D. Advance the cam, or by other means open the intake valve sooner. (tighter lobe sep)
E. Improve the low-lift intake valve flow numbers.
F. All of the above
