Crhis ..I'll put a little of the 221 #2 and the 238 including some Mobile 1 in the freezer for a couple of days then post back here with my results..I'm curious to see what happens alsoquote:
Originally posted by Chris B.:
Thanks Bob! So will it say "slick" and protect in sub 0 temps? I think I'll put a dab in the freezer and see what happends. If it does harden a bit will this cause the ball joints to wear faster?
I am leaving my samples in the deep freeze till the week-end..I'll post back then...they have been in there since Monday...we'll see what happens.quote:
Ok after 12 hours in the freezer the 221#2 was a lot harder but when I pushed my finger into it it was still stuck to it and was still stringey. Will this be a problem for the ball joints in the winter? The 221 lasts so long that there is no way it will be gone by winter time so it will still be in the boots.
What did you find Greaser?
I feel that tacky grease is better than grease that will stay malable,but will wash out leaving a suspension componant vunerable to rust...your power steering pump's hydralics are actually quite powerfull..if you feel the stiff grease will give it a hard time working the steering...I've seen drag links get bent by people trying to get a jammed tire out between two rocks with a Jeep..if a steering pump can bend steel,it will move stiff grease around no problem.quote:
Greaser, My wife is the same way! "what is this in my freezer"!!!Got to love em'!
I only had the 221#2 but it was still tackey and firm. when it is below 0 will do you think this grease will be protecting the joints at all? I wonder if I should try the 274 Moly grease in the winter? But the 221#2 will still be in the boot so I wonder if the 274 will work? How would I get the 221 out of the boot or should I not worry about it?
My wife can't understand why I loose sleep worrying about stuff like this!Maybe I am worrying to much, what do you think!?!?!?
I like the 238..Schaeffers grease with the most additives...they clain their best...go to their web site and check it out...where you live you won't even have to think twice about really cold weatherquote:
Originally posted by wlkjr:
So which one would you recommend for all round use in Georgia, the 221 or 238? And what would the difference be?
