Interested in the thoughts and opinions of this group.
I stored, for the first time, a 2008 Mazda MX5 in an unheated garage in Northern Wisconsin. It will remain untouched until April. I think I've done all the usual storage things and was planning to pull the plugs and use fogging spray, but the tube on the aerosol can was too short. As most don't seem to think this fogging step is necessary and the car is stored 400 miles from where I live, it remains in an "unfogged" condition.
So, is this important?
On one hand, when the car was shut off for the final time, each cylinder had a mouthful of air including ambient moisture - maybe at a dew point of 45 degrees. There is some opportunity for air to flow in and out of cylinders while stored, but not much. Now, when the temperature drops below 45(actually well below zero there), condensation seems inevitable. So why wouldn't that be a problem?
On the other hand, lots of people store lots of cars without doing this and they seem to survive quite nicely. If condensation like I theorize is a problem, it would also show up in shorter-term storage, like on a dealer's lot or cars sitting in an airport parking lot for a couple weeks. Plus, despite the best efforts of piston rings, I assume there is some "oiliness" left on cylinder walls.
I'm now armed with a nice, long tube to attach to the fogging spray(Seafoam spray comes with one)and will go the fogging route next fall. Until then, what do you guys think? Should I make an emergency 400 mile fogging trip?
Oh, and it doesn't use Mobil 1, so I'm confident there is still iron left to rust.
Thanks.
Thanks.
