Hi all, I have a 2003 Silverado and I just found that the upper ball joint boot on the passenger side is not sealed anymore! I filled it up with schaeffers 221#2 untill the old factory greese was squirted out if the bottom. I drive it around the block a few times to relieve the exess and wiped it off the joints so they were nice and clean. I checked them over a few days to make sure they were not still squerting and all was good! Then 2 months later the one broke. I don't think it poped but it looks like the seam has come apart from the metal if you know what I mean. I'm not sure how long it was like this but the Schaeffers 221 looked good and not dirty.
Do you think the ball joint has had any damage done because of this? I just found it today and will call the dealer to have it fixed. Thanks!
