MotoMaster (Canadian Tire) Synthetic grease..who makes it?
Windsor,Ontario
To me it's seems to be Exxon..looks,smells the same as my tube of Mobil 1 grease...anybody know for sure who supplies it for Canadian Tire?
I don't know but I do not like it. It's red and it drools all over the place. I can't keep it from bleeding out of my grease gun and it has been slowly melting out of there for over a year now!
Steve
quote:
Steve
Did you release the spring tension on the grease gun when you put it away? If you did and it is still leaking then the grease leaves a lot to be desired.
The tension is still on the grease. I used it about 3 months ago and have it hanging straight up...there is red stuff pooled on the bottom of the lever and the plunger. Perhaps it would be okay for a truly closed system but they are pretty rare.
I did a bit of reading on here and this is supposed to be normal?
Steve
